Ir para o conteúdo principal
Nintendo 64 Metal Plate Replacement
O que você precisa
  1. Nintendo 64 Metal Plate Replacement, Top Cover: passo 1, imagem 1 %32
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Metal Plate Replacement: passo 2, imagem 1 %32
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Metal Plate Replacement: passo 3, imagem 1 %32
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Metal Plate Replacement: passo 4, imagem 1 %32
    • Remove the two front feet of the N64.
  5. Nintendo 64 Metal Plate Replacement: passo 5, imagem 1 %32
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Metal Plate Replacement, Metal Plate: passo 6, imagem 1 %32 Nintendo 64 Metal Plate Replacement, Metal Plate: passo 6, imagem 2 %32
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Metal Plate Replacement: passo 7, imagem 1 %32 Nintendo 64 Metal Plate Replacement: passo 7, imagem 2 %32
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Metal Plate Replacement: passo 8, imagem 1 %32
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Metal Plate Replacement: passo 9, imagem 1 %32
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Metal Plate Replacement: passo 10, imagem 1 %32
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Metal Plate Replacement: passo 11, imagem 1 %32 Nintendo 64 Metal Plate Replacement: passo 11, imagem 2 %32
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Metal Plate Replacement: passo 12, imagem 1 %32 Nintendo 64 Metal Plate Replacement: passo 12, imagem 2 %32
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Metal Plate Replacement: passo 13, imagem 1 %32 Nintendo 64 Metal Plate Replacement: passo 13, imagem 2 %32
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Metal Plate Replacement: passo 14, imagem 1 %32
    • Lift off and remove the metal plate as indicated in the example.
Conclusão
5 outras pessoas executaram este guia.
LisaF818
Membro desde: 11/29/09
143 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-4, Regan Fall 2009 Membro de Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
Membros da 7
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 40
Duração total: 11,488
