Introdução
This guide will show you how to replace the most important part of your Nintendo 3DS XL, the motherboard. The motherboard is the central part of your device, it's where everything happens!
O que você precisa
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set it aside.
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
Position the device such that the game cartridge slot is located at the top.
Locate the IR board located on the upper right side of the motherboard.
Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
Using a plastic opening tool, pry off the Wi-Fi board.
The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
48 outras pessoas executaram este guia.
13 comentários
Does anyone know how to fix the flap on the ribbon because I accidentally removed the whole thing
How do you fix it so it will stop shutting down on start up?
my 3DS XL in turn on, speaker making cracking sound, no display, then power off. is this motherboard issue.
I have the same problem, did you were able to fix it ?
soyeliel -
