Ir para o conteúdo principal
Nintendo 3DS XL Microphone Replacement
O que você precisa
  1. Nintendo 3DS XL Microphone Replacement, Battery: passo 1, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Battery: passo 1, imagem 2 %32
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
    Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
    justjustintuber - Responder
    what type screwdriver do i use?!? its so small!!!!
    Matthew - Responder
    I had success using a #00 Phillips head
    Jake S -
    Can't clip the front of the back cover back in
    Macro Man - Responder
    I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
    Issu -
    I found these were actually #00
    Demosthien - Responder
    The screws in the 1st picture are stripped. What screwdriver head do I use?
    Adric101 - Responder
  2. Nintendo 3DS XL Microphone Replacement: passo 2, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 2, imagem 2 %32
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
    Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
    Jordan Kelly - Responder
  3. Nintendo 3DS XL Microphone Replacement: passo 3, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
    My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
    Corban Bennett - Responder
  4. Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 2 %32
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Nintendo 3DS XL Microphone Replacement: passo 5, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 5, imagem 2 %32
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
  6. Nintendo 3DS XL Microphone Replacement: passo 6, imagem 1 %32
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
  7. Nintendo 3DS XL Microphone Replacement: passo 7, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 3 %32
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Nintendo 3DS XL Microphone Replacement: passo 8, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 3 %32
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. Nintendo 3DS XL Microphone Replacement: passo 9, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 3 %32
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
  10. Nintendo 3DS XL Microphone Replacement: passo 10, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 10, imagem 2 %32
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
Conclusão
4 outras pessoas executaram este guia.
Charlene Donlon
Membro desde: 04/08/14
10.215 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 9-13, Regan Spring 2014 Membro de Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
Membros da 5
Autoria de 44 guias
2 comentários
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Responder
please learn to repair the mic of new 3ds xl
andrew.hws - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 27
Últimos 30 dias: 103
Duração total: 10,814
