Ir para o conteúdo principal
Nintendo 3DS XL Microphone Replacement
O que você precisa
  1. Nintendo 3DS XL Microphone Replacement, Battery: passo 1, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Battery: passo 1, imagem 2 %32
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Microphone Replacement: passo 2, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 2, imagem 2 %32
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Microphone Replacement: passo 3, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  4. Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 1 %32 Nintendo 3DS XL Microphone Replacement, Microphone: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Nintendo 3DS XL Microphone Replacement: passo 5, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 5, imagem 2 %32
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
  6. Nintendo 3DS XL Microphone Replacement: passo 6, imagem 1 %32
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
  7. Nintendo 3DS XL Microphone Replacement: passo 7, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 7, imagem 3 %32
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Nintendo 3DS XL Microphone Replacement: passo 8, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 8, imagem 3 %32
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. Nintendo 3DS XL Microphone Replacement: passo 9, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 2 %32 Nintendo 3DS XL Microphone Replacement: passo 9, imagem 3 %32
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
  10. Nintendo 3DS XL Microphone Replacement: passo 10, imagem 1 %32 Nintendo 3DS XL Microphone Replacement: passo 10, imagem 2 %32
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
Conclusão
4 outras pessoas executaram este guia.
Charlene Donlon
Membro desde: 04/08/14
10.343 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 9-13, Regan Spring 2014 Membro de Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
Membros da 5
Autoria de 44 guias
2 comentários
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Responder
please learn to repair the mic of new 3ds xl
andrew.hws - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 38
Últimos 30 dias: 144
Duração total: 11,170
