Ir para o conteúdo principal
Nintendo 3DS Motherboard Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: passo 1, imagem 1 %32 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: passo 2, imagem 1 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 2, imagem 2 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 2, imagem 3 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: passo 3, imagem 1 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 3, imagem 2 %32
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: passo 4, imagem 1 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 4, imagem 2 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 4, imagem 3 %32
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: passo 5, imagem 1 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 5, imagem 2 %32 Nintendo 3DS Motherboard Assembly Replacement: passo 5, imagem 3 %32
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  6. Nintendo 3DS Motherboard Assembly Replacement: passo 6, imagem 1 %32
    • Remove the motherboard assembly from the rest of the device.
Conclusão
David Hodson
Membro desde: 04/13/10
152.626 Reputação
Autoria de 127 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,602
