Introdução
What's that? I can't hear you! I think you need to install a new microphone.
O que você precisa
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
Pull the microphone straight up out of the upper case.
3 outras pessoas executaram este guia.
2 comentários
Can someone please tell me how to acquire a new microphone chip?
You are able to purchase replacement microphones on amazon for less than $10 USD
