Introdução
Having trouble with your 3DS' IR port? A new IR board could help.
Peças
Nenhum componente especificado.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Use the flat end of a spudger to lightly pry the IR board off the motherboard.
Grab the edges of the IR board with two fingers and lift it from the motherboard.
Uma outra pessoa concluiu este guia.
