Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unscrew the four Phillips #00 screws along the top of the back cover.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
46 outras pessoas executaram este guia.
7 comentários
Where do you buy a new battery from for your nintendo 3ds?
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
