Ir para o conteúdo principal
Nintendo 3DS Battery Replacement
O que você precisa
  1. Nintendo 3DS Battery Replacement, Loosen the rear screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Battery Replacement, Remove the rear cover: passo 2, imagem 1 %32 Nintendo 3DS Battery Replacement, Remove the rear cover: passo 2, imagem 2 %32
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: passo 3, imagem 1 %32 Nintendo 3DS Battery Replacement, Battery: passo 3, imagem 2 %32 Nintendo 3DS Battery Replacement, Battery: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
Conclusão
63 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
154.622 Reputação
Autoria de 127 guias
9Comentários do guia
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Responder
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - Responder
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Responder
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Responder
Comentar
Visualizações:
Últimas 24 horas: 86
Últimos 7 dias: 1,028
Últimos 30 dias: 2,937
Ao todo: 121,447
