Ir para o conteúdo principal
Nintendo 3DS 2015 Circle Pad Replacement
O que você precisa
  1. Nintendo 3DS 2015 Circle Pad Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Circle Pad Replacement: passo 2, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 2, imagem 2 %32
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Circle Pad Replacement: passo 3, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 3, imagem 2 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Circle Pad Replacement, SD Card Reader: passo 4, imagem 1 %32
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Circle Pad Replacement: passo 5, imagem 1 %32
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Circle Pad Replacement: passo 6, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 6, imagem 2 %32
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: passo 7, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: passo 7, imagem 2 %32 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: passo 7, imagem 3 %32
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Circle Pad Replacement: passo 8, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 8, imagem 2 %32
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Circle Pad Replacement: passo 9, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 9, imagem 2 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 9, imagem 3 %32
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: passo 10, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: passo 10, imagem 2 %32 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: passo 10, imagem 3 %32
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
  11. Nintendo 3DS 2015 Circle Pad Replacement: passo 11, imagem 1 %32 Nintendo 3DS 2015 Circle Pad Replacement: passo 11, imagem 2 %32
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
Conclusão
4 outras pessoas executaram este guia.
Michael
Membro desde: 10/14/16
149 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-6, Livingston Fall 2016 Membro de Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
Membros da 4
Autoria de 35 guias
Um comentário
thank you for the help
Crichton Vance - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 65
Últimos 30 dias: 316
Duração total: 6,598
