Introdução
If your 3DS joystick is not responding, follow these steps to replace the joystick pad and get your device working again. Watch out for delicate ribbon cables in the device. There is a loose black washer in the joystick housing. Be sure not to lose it.
O que você precisa
Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Locate the joystick assembly near the top right corner of the motherboard.
Remove the two 8mm Phillips #00 screws from the back of the joystick.
Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
4 outras pessoas executaram este guia.
