Ir para o conteúdo principal
Nintendo 2DS Volume Slider Replacement
O que você precisa
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, imagem 1 %32 Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, imagem 2 %32 Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, imagem 3 %32
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 2DS Volume Slider Replacement: passo 2, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 2, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 2, imagem 3 %32
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 2DS Volume Slider Replacement: passo 3, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 3, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 3, imagem 3 %32
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
    Pergunte ao FixBot
    Comentar
  4. Nintendo 2DS Volume Slider Replacement: passo 4, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 4, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 4, imagem 3 %32
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
    Pergunte ao FixBot
    Comentar
  5. Nintendo 2DS Volume Slider Replacement: passo 5, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 5, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
    Pergunte ao FixBot
    Comentar
  6. Nintendo 2DS Volume Slider Replacement: passo 6, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 6, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 6, imagem 3 %32
    • Gently pry the side that holds the volume slider off of the 2DS.
    Pergunte ao FixBot
    Comentar
  7. Nintendo 2DS Volume Slider Replacement: passo 7, imagem 1 %32 Nintendo 2DS Volume Slider Replacement: passo 7, imagem 2 %32 Nintendo 2DS Volume Slider Replacement: passo 7, imagem 3 %32
    • Remove the volume slider from the sidebar housing.
    • When reassembling, ensure that the volume slider is volume slider is connected to the slider on the motherboard labeled VR1.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
S. Leng
Membro desde: 10/24/22
166 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 48
Últimos 30 dias: 234
Ao todo: 6,621
