O que você precisa
Flip the device to show the back.
Unscrew the two screws on the top half of the device.
Lift off the panel using the small pull area at the very top. (Marked in yellow).
Remove battery.
Unscrew the 10 screws holding in the back panel.
Carefully lift up the panel from the bottom and unhook the ribbon.
Gently lift off the coloured frames on the sides.
Remove L&R triggers
I recommend using tweezers to push back the spring so allow easy lift and placement.
Remove circle pad module.
Remove wifi module
Unseat the ribbon cables.
2 big ones mid board, 1 center bottom edge, 2 Bottom right corner.
Unscrew 11 Motherboard screws.
Lift off motherboard and top colored piece.
Lift off screen carefully. It had adhesive so don't be surprised.
