Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the ten Phillips screws attaching the rear panel.
Carefully pull the rear panel straight up from the device.
Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
Remove the cable from the connector
9 outras pessoas executaram este guia.
2 comentários
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
