Introdução
If the blender is too loud, the suction cups may be damaged or loose. This guide will help you to replace damaged suction cups.
O que você precisa
Using the Phillips #1 screwdriver, remove the 5 screws holding the outer base.
Lift the base up to remove it.
Quase terminado!
Conclusão
