Ir para o conteúdo principal
Ninja Professional Blender BL660 Suction Cups on Base Replacement
O que você precisa
  1. Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: passo 1, imagem 1 %32 Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 5 screws holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Suction Cups on Base Replacement: passo 2, imagem 1 %32 Ninja Professional Blender BL660 Suction Cups on Base Replacement: passo 2, imagem 2 %32
    • Turn the base panel upside down to reveal the suction cup feet.
  3. Ninja Professional Blender BL660 Suction Cups on Base Replacement: passo 3, imagem 1 %32
    • Push the stopper on the suction cup foot through the bottom panel using the iFixit plastic opening tool.
  4. Ninja Professional Blender BL660 Suction Cups on Base Replacement: passo 4, imagem 1 %32 Ninja Professional Blender BL660 Suction Cups on Base Replacement: passo 4, imagem 2 %32
    • Once stopper has passed through the bottom panel, pull suction cup foot out.
    • Replace suction cup feet as needed.
    • Ninja does not sell suction cup feet. You will need to obtain them from other third party vendors.
Conclusão
Um comentário
Where did you get the suction cups from?
camoramirez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 53
Duração total: 4,932
