Introdução
This guide will show how to remove the outer and inner blender base and sections from your Ninja Professional Blender BL660 Blender. This will allow you to get access to the inner components.
O que você precisa
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Quase terminado!
Conclusão
