Ir para o conteúdo principal
Ninja Professional Blender BL660 Blender Base Replacement
O que você precisa
  1. Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: passo 1, imagem 1 %32 Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Blender Base Replacement: passo 2, imagem 1 %32 Ninja Professional Blender BL660 Blender Base Replacement: passo 2, imagem 2 %32
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Blender Base Replacement: passo 3, imagem 1 %32 Ninja Professional Blender BL660 Blender Base Replacement: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Blender Base Replacement: passo 4, imagem 1 %32 Ninja Professional Blender BL660 Blender Base Replacement: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Blender Base Replacement: passo 5, imagem 1 %32 Ninja Professional Blender BL660 Blender Base Replacement: passo 5, imagem 2 %32
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 81
Duração total: 2,938
