Ir para o conteúdo principal
Ninja Professional Blender 1100 watt Blade Replacement
  1. Ninja Professional Blender 1100 watt Blade Replacement, Blades: passo 1, imagem 1 %32
    • Unplug blender.
    • Remove the pitcher from the base by turning it counter clockwise so the pitcher is not aligned with the arrows on the base.
  2. Ninja Professional Blender 1100 watt Blade Replacement: passo 2, imagem 1 %32 Ninja Professional Blender 1100 watt Blade Replacement: passo 2, imagem 2 %32
    • Press the release button on top of the lid.
    • Pull the lid off.
    • Use both hands when taking off the lid. You may need to pull hard if there is water between the lid and the pitcher, which will create a tight suction.
  3. Ninja Professional Blender 1100 watt Blade Replacement: passo 3, imagem 1 %32
    • Blades are very sharp.
    • Use one hand to pull the blade housing out of the pitcher while using the other hand to hold onto the pitcher handle.
  4. Ninja Professional Blender 1100 watt Blade Replacement: passo 4, imagem 1 %32 Ninja Professional Blender 1100 watt Blade Replacement: passo 4, imagem 2 %32
    • Insert the new blade house into the pitcher and align it so it fits onto the mounting gear.
Conclusão
4 outras pessoas executaram este guia.
Equipe
CSU Fullerton, Team 1-1, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-1, Bruce Fall 2015
CSUF-BRUCE-F15S1G1
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 63
Duração total: 3,702
