Ir para o conteúdo principal
Ninja NJ600 Fan Replacement
O que você precisa
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: passo 1, imagem 1 %32 Ninja NJ600 Fan Replacement, Blender Base Cover: passo 1, imagem 2 %32
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: passo 2, imagem 1 %32 Ninja NJ600 Fan Replacement: passo 2, imagem 2 %32
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: passo 3, imagem 1 %32 Ninja NJ600 Fan Replacement: passo 3, imagem 2 %32 Ninja NJ600 Fan Replacement: passo 3, imagem 3 %32
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: passo 4, imagem 1 %32
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: passo 5, imagem 1 %32
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: passo 6, imagem 1 %32 Ninja NJ600 Fan Replacement: passo 6, imagem 2 %32
    • Slide the washer and fan off of the screw.
Conclusão
Ryan Heller
Membro desde: 04/01/15
107 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-2, Lancaster Spring 2015 Membro de Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,378
