Introdução
This will work as a prerequisite guide for all other guides. This helps us break down the device into the main base layer.
O que você precisa
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Uma outra pessoa concluiu este guia.
Um comentário
Hey Tommee where can I get a circuit board for the ninja bl 773.
