Ir para o conteúdo principal
Ninja Mega Kitchen System BL770 Circuit Base Replacement
O que você precisa
  1. Ninja Mega Kitchen System BL770 Circuit Base Replacement, Circuit Base: passo 1, imagem 1 %32 Ninja Mega Kitchen System BL770 Circuit Base Replacement, Circuit Base: passo 1, imagem 2 %32
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Circuit Base Replacement: passo 2, imagem 1 %32
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Circuit Base Replacement: passo 3, imagem 1 %32 Ninja Mega Kitchen System BL770 Circuit Base Replacement: passo 3, imagem 2 %32 Ninja Mega Kitchen System BL770 Circuit Base Replacement: passo 3, imagem 3 %32
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Circuit Base Replacement: passo 4, imagem 1 %32
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Hey Tommee where can I get a circuit board for the ninja bl 773.
Bhesham Sochan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 1,385
