Ir para o conteúdo principal
Ninja Master Prep QB900B button replacement
O que você precisa
  1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: passo 1, imagem 1 %32
    • Place the blender to the side.
  2. Ninja Master Prep QB900B button replacement: passo 2, imagem 1 %32 Ninja Master Prep QB900B button replacement: passo 2, imagem 2 %32
    • Remove the two highlighted screws with a Phillips #2 Screw Driver
    • Gently pull off the top.
  3. Ninja Master Prep QB900B button replacement, Button: passo 3, imagem 1 %32
    • Remove the highlighted screws.
  4. Ninja Master Prep QB900B button replacement: passo 4, imagem 1 %32
    • Pull out the highlighted spring.
    • Now wash the button with soap and water, and follow the guide backwards to reassemble.
Conclusão
Kamal Taha
Membro desde: 08/27/15
679 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Fall 2015 Membro de USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Membros
Autoria de 5 guias
2 comentários
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Responder
turns out it was a security torx. how annoying.
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 24
Ao todo: 2,040
