Introdução
In the Ninja Foodi SP101, the cooling fan is a key part to ensure the unit returns to room temperature after use. Before starting this guide, ensure that the Foodi is disconnected from power and completely cool.
O que você precisa
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
