Ir para o conteúdo principal
Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement
O que você precisa
  1. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement, Valve: passo 1, imagem 1 %32
    • Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Remove bottom cover
  2. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 2, imagem 1 %32
    • Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Remover tube protection plate
  3. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 3, imagem 1 %32 Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: passo 3, imagem 2 %32
    • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
Conclusão
Naser Aldousari
Membro desde: 10/10/17
310 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S13-G69, Cagle Fall 2017 Membro de USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
Membros da 4
Autoria de 3 guias
2 comentários
Where can I get the replacement water valve?
Mark Peters - Responder
Anyone have a source for the valve?
ErrorCode67 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 1,916
