Introdução
Tubing is prone to leaking and replacing the hot water tubing may eliminate any problems you may be facing with your device or prevent problems down the road. Replacing the main hot water tube involves removing screws on both the top and bottom panel, so it may be a good idea to use the iFixit magnetic pad to keep track of loose screws.
O que você precisa
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
Remove the single 6mm #1 Phillips-head screw from the side of the unit.
Squeeze connector and pull tubing away from heater.
Inspect tubing for damage and/or weak spots and replace if necessary.
2 comentários
what size tubing does this require?
