Introdução
This guide will teach you how to replace the drip stop toggle and/or the brew basket of your Ninja Coffee Bar® Single-Serve System. In a lot of coffee machines after heavy use the brew based can start to leak, and these fixes are very similar, so that is why we did both of these fixes together. Warning: be very careful when unscrewing the brew basket because there is a small spring that releases the drip stop toggle that needs to stay in place. Also you will need a longer skinnier Phillips head screwdriver than the one in the iFixit tool kit to complete this repair.
O que você precisa
3 comentários
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
* this works on the ninja coffee bar larger system as well
