Ir para o conteúdo principal
Nikon N80 Battery Replacement
  1. Nikon N80 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Battery Replacement: passo 2, imagem 1 %32
    • Turn the camera upside down to reveal the battery chamber cover.
    • This camera is missing the battery chamber cover.
    • Slide on the lock lever and remove the battery chamber cover.
  3. Nikon N80 Battery Replacement: passo 3, imagem 1 %32
    • Turn the camera back over and let the two CR123A/ DL123A batteries slide out.
    • Discard the old batteries responsibly.
  4. Nikon N80 Battery Replacement: passo 4, imagem 1 %32
    • Use the image on the yellow sticker within the battery chamber to properly place the new batteries back in their compartments.
Conclusão
Uma outra pessoa concluiu este guia.
Maegan Viloria
Membro desde: 09/14/15
717 Reputação
Autoria de 5 guias
Equipe
CSU Fullerton, Team 1-7, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-7, Bruce Fall 2015
CSUF-BRUCE-F15S1G7
Membros da 3
Autoria de 10 guias
Um comentário
can cr123a rechargeable batteries be used
David Strom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 97
Duração total: 5,123
