Pular para o conteúdo principal
Introdução
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  4. Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  5. Remove the battery compartment from the camera.
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Conclusão
2 outras pessoas concluíram este guia.
Zachary Phillips
Membro desde: 08-04-2011
205 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 25-26, Garner Spring 2011 Membro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membros
7 Guias de autoria
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 61
Todo: 10,211
