Introdução
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
O que você precisa
Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
4 outras pessoas executaram este guia.
Um comentário
Hey, i lost the bracket… do u guys have any idea where could i get one?
