Ir para o conteúdo principal
Nikon N2000 (F301) Battery Compartment Replacement
O que você precisa
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: passo 2, imagem 1 %32
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: passo 3, imagem 1 %32
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: passo 4, imagem 1 %32
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: passo 5, imagem 1 %32
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Conclusão
4 outras pessoas executaram este guia.
Zachary Phillips
Membro desde: 04/08/11
247 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-26, Garner Spring 2011 Membro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
Membros da 3
Autoria de 12 guias
Um comentário
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 153
Duração total: 17,265
