Introdução
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
O que você precisa
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
5 outras pessoas executaram este guia.
Um comentário
where can I order the "3 loose pieces and the ring that goes in under the bayonet mount?
