Ir para o conteúdo principal
Nikon D90 Rear Case Replacement
O que você precisa
  1. Nikon D90 Rear Case Replacement, Rear Case: passo 1, imagem 1 %32 Nikon D90 Rear Case Replacement, Rear Case: passo 1, imagem 2 %32
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 Rear Case Replacement: passo 2, imagem 1 %32
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 Rear Case Replacement: passo 3, imagem 1 %32
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 Rear Case Replacement: passo 4, imagem 1 %32
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 Rear Case Replacement: passo 5, imagem 1 %32
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 Rear Case Replacement: passo 6, imagem 1 %32 Nikon D90 Rear Case Replacement: passo 6, imagem 2 %32 Nikon D90 Rear Case Replacement: passo 6, imagem 3 %32
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 Rear Case Replacement: passo 7, imagem 1 %32 Nikon D90 Rear Case Replacement: passo 7, imagem 2 %32
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 Rear Case Replacement: passo 8, imagem 1 %32
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 Rear Case Replacement: passo 9, imagem 1 %32 Nikon D90 Rear Case Replacement: passo 9, imagem 2 %32 Nikon D90 Rear Case Replacement: passo 9, imagem 3 %32
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 Rear Case Replacement: passo 10, imagem 1 %32
    • Separate the rear casing from the camera.
Conclusão
8 outras pessoas executaram este guia.
Ryan Lutz
Membro desde: 09/27/11
3.011 Reputação
Autoria de 3 guias
2 comentários
good guidance,easy to follow,thanks
ramalingeswarao kaza - Responder
I want to replace my Nikon D90 DSLR bad LCD, this guide will save me from costly repairs.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 4,255
