Ir para o conteúdo principal
Nikon D90 Flash Bulb Replacement
O que você precisa
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, imagem 1 %32 Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, imagem 2 %32 Nikon D90 Flash Bulb Replacement, Open the Flash: passo 1, imagem 3 %32
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: passo 2, imagem 1 %32 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: passo 2, imagem 2 %32
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, imagem 1 %32 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, imagem 2 %32 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: passo 3, imagem 3 %32
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: passo 4, imagem 1 %32 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: passo 4, imagem 2 %32
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, imagem 1 %32 Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, imagem 2 %32 Nikon D90 Flash Bulb Replacement, Removing the Bulb: passo 5, imagem 3 %32
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
Conclusão
8 outras pessoas executaram este guia.
jonothon cawley
Membro desde: 10/20/14
354 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
Membros da 3
Autoria de 6 guias
2 comentários
thanks for instruction…………really helpfull
hebi - Responder
Hi guys do you know where to get this bulb?please help
Martin Mitter - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 7,018
