Ir para o conteúdo principal
Nikon D7100 Headphone/Microphone Replacement
O que você precisa
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: passo 1, imagem 1 %32
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: passo 2, imagem 1 %32
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: passo 3, imagem 1 %32
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: passo 4, imagem 1 %32
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: passo 5, imagem 1 %32
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: passo 6, imagem 1 %32
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: passo 7, imagem 1 %32
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: passo 8, imagem 1 %32
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: passo 9, imagem 1 %32 Nikon D7100 Headphone/Microphone Replacement: passo 9, imagem 2 %32
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: passo 10, imagem 1 %32
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: passo 11, imagem 1 %32
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: passo 12, imagem 1 %32 Nikon D7100 Headphone/Microphone Replacement: passo 12, imagem 2 %32
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: passo 13, imagem 1 %32
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: passo 14, imagem 1 %32
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: passo 15, imagem 1 %32
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: passo 16, imagem 1 %32
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: passo 17, imagem 1 %32
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: passo 18, imagem 1 %32
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
Conclusão
Uma outra pessoa concluiu este guia.
Wesley Eveld
Membro desde: 02/20/18
732 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S11-G6, Cheng Spring 2018 Membro de USF Tampa, Team S11-G6, Cheng Spring 2018
USFT-CHENG-S18S11G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,070
