Ir para o conteúdo principal
Nikon D7000 Shutter Assembly Replacement
O que você precisa
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: passo 2, imagem 1 %32
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: passo 3, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 3, imagem 2 %32
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: passo 4, imagem 1 %32
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: passo 5, imagem 1 %32
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Shutter Assembly Replacement: passo 6, imagem 1 %32
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Shutter Assembly Replacement: passo 7, imagem 1 %32
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: passo 8, imagem 1 %32
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Shutter Assembly Replacement: passo 9, imagem 1 %32
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: passo 10, imagem 1 %32
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: passo 11, imagem 1 %32
    • Gently pull the SD card cover off.
  12. Nikon D7000 Shutter Assembly Replacement: passo 12, imagem 1 %32
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: passo 13, imagem 1 %32
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: passo 14, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 14, imagem 2 %32 Nikon D7000 Shutter Assembly Replacement: passo 14, imagem 3 %32
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: passo 15, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 15, imagem 2 %32
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: passo 16, imagem 1 %32
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Shutter Assembly Replacement: passo 17, imagem 1 %32
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Shutter Assembly Replacement: passo 18, imagem 1 %32
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: passo 19, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 19, imagem 2 %32 Nikon D7000 Shutter Assembly Replacement: passo 19, imagem 3 %32
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: passo 20, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 20, imagem 2 %32
  21. Nikon D7000 Shutter Assembly Replacement: passo 21, imagem 1 %32
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: passo 22, imagem 1 %32
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: passo 23, imagem 1 %32
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: passo 24, imagem 1 %32
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: passo 25, imagem 1 %32
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Shutter Assembly Replacement: passo 26, imagem 1 %32
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: passo 27, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement, Image Sensor: passo 27, imagem 2 %32
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: passo 28, imagem 1 %32
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Shutter Assembly Replacement: passo 29, imagem 1 %32
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: passo 30, imagem 1 %32
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: passo 31, imagem 1 %32
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: passo 32, imagem 1 %32
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Shutter Assembly Replacement: passo 33, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 33, imagem 2 %32
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: passo 34, imagem 1 %32
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: passo 35, imagem 1 %32
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: passo 36, imagem 1 %32
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: passo 37, imagem 1 %32
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: passo 38, imagem 1 %32
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: passo 39, imagem 1 %32
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: passo 40, imagem 1 %32
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: passo 41, imagem 1 %32
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: passo 42, imagem 1 %32
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: passo 43, imagem 1 %32
    • Remove the top case.
  44. Nikon D7000 Shutter Assembly Replacement: passo 44, imagem 1 %32
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Shutter Assembly Replacement: passo 45, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 45, imagem 2 %32 Nikon D7000 Shutter Assembly Replacement: passo 45, imagem 3 %32
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Shutter Assembly Replacement: passo 46, imagem 1 %32
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Shutter Assembly Replacement: passo 47, imagem 1 %32
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Shutter Assembly Replacement: passo 48, imagem 1 %32
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: passo 49, imagem 1 %32
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: passo 50, imagem 1 %32
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: passo 51, imagem 1 %32
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: passo 52, imagem 1 %32 Nikon D7000 Shutter Assembly Replacement: passo 52, imagem 2 %32
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Shutter Assembly Replacement: passo 53, imagem 1 %32
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: passo 54, imagem 1 %32
    • Separate the shutter assembly from the camera body.
Conclusão
34 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-6, Lancaster Spring 2015 Membro de Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
Membros da 3
Autoria de 5 guias
10 comentários
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - Responder
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - Responder
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - Responder
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - Responder
How to reassemble diopter adjustment?
Jerome - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 62
Duração total: 18,982
