Introdução
Use this guide to replace the mirror box and viewfinder.
O que você precisa
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Pull out ribbon cable from circuit asembly near front left of device.
5 outras pessoas executaram este guia.
