Introdução
Use this guide to replace the LCD board, which also houses the physical switches for the buttons on the rear cover.
O que você precisa
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Use your thumbnails to push the ZIF cable lock toward the LCD.
Pull the LCD ribbon cable out of its socket.
Remove the three 3.1 mm Phillips screws securing the LCD board to the rear cover.
4 outras pessoas executaram este guia.
