Introdução
Use this guide to replace the CCD sensor board.
O que você precisa
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
Use your fingernail to flip up the ZIF cable retaining flap on each socket.
Pull the ribbon cable straight out of its socket.
De-route the two leads routed over the connector boxed in yellow.
Use your thumbnails to push the connector out of its socket.
25 outras pessoas executaram este guia.
2 comentários
Great instructions.
One important note: When re-installing the CCD board ribbon cable into the CCD board, the cable will go into the connector about 2mm and feel like it's seated. However, the cable must go 3mm-4mm into the connector. Otherwise, you will get a "This Card Cannot Be Used" error message each time you depress the shutter button.
Great article.
