Ir para o conteúdo principal
Nikon D610 Battery Replacement
O que você precisa
  1. Nikon D610 Battery Replacement, Battery: passo 1, imagem 1 %32
    • First, power off the device.
  2. Nikon D610 Battery Replacement: passo 2, imagem 1 %32 Nikon D610 Battery Replacement: passo 2, imagem 2 %32 Nikon D610 Battery Replacement: passo 2, imagem 3 %32
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: passo 3, imagem 1 %32 Nikon D610 Battery Replacement: passo 3, imagem 2 %32
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Conclusão
Daniel Eagan
Membro desde: 02/10/16
606 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-4, Lacy Spring 2016 Membro de USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
Membros da 3
Autoria de 6 guias
Um comentário
This is my kind of fixing )
Loic - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 1,438
