Ir para o conteúdo principal
Nikon D5100 Memory Card Replacement
  1. Nikon D5100 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Nikon D5100 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32 Nikon D5100 Memory Card Replacement, Memory Card: passo 1, imagem 3 %32
    • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
  2. Nikon D5100 Memory Card Replacement: passo 2, imagem 1 %32
    • Eject the memory card by pressing it into its slot until you hear a soft "click."
  3. Nikon D5100 Memory Card Replacement: passo 3, imagem 1 %32
    • Using thumb and forefinger, gently remove the SD card from its slot.
Conclusão
Liz
Membro desde: 04/25/14
1.296 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 10-54, Amido Spring 2014 Membro de Cal Poly, Team 10-54, Amido Spring 2014
CPSU-AMIDO-S14S10G54
4 Membros
5 Guias de autoria
Um comentário
isn't this procedure in the user manual?
Happy Fixer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,193
