Ir para o conteúdo principal
Nikon D5100 Battery Door Replacement
O que você precisa
  1. Nikon D5100 Battery Door Replacement, Battery Door: passo 1, imagem 1 %32 Nikon D5100 Battery Door Replacement, Battery Door: passo 1, imagem 2 %32 Nikon D5100 Battery Door Replacement, Battery Door: passo 1, imagem 3 %32
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: passo 2, imagem 1 %32 Nikon D5100 Battery Door Replacement: passo 2, imagem 2 %32 Nikon D5100 Battery Door Replacement: passo 2, imagem 3 %32
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: passo 3, imagem 1 %32 Nikon D5100 Battery Door Replacement: passo 3, imagem 2 %32 Nikon D5100 Battery Door Replacement: passo 3, imagem 3 %32
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: passo 4, imagem 1 %32
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: passo 5, imagem 1 %32 Nikon D5100 Battery Door Replacement: passo 5, imagem 2 %32
    • Turn on the camera to check that the battery is properly secure.
Linha de Chegada
Michelle Tran
Membro desde: 02/24/15
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-1, Green Winter 2015 Membro de Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Membros
4 Guias de autoria
Um comentário
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 38
Duração total: 2,513
