Ir para o conteúdo principal
Nikon D5000 Sensor Filter Replacement
O que você precisa
  1. Nikon D5000 Sensor Filter Replacement, Back Panel: passo 1, imagem 1 %32 Nikon D5000 Sensor Filter Replacement, Back Panel: passo 1, imagem 2 %32 Nikon D5000 Sensor Filter Replacement, Back Panel: passo 1, imagem 3 %32
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Sensor Filter Replacement: passo 2, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 2, imagem 2 %32 Nikon D5000 Sensor Filter Replacement: passo 2, imagem 3 %32
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Sensor Filter Replacement, Sensor Filter: passo 3, imagem 1 %32 Nikon D5000 Sensor Filter Replacement, Sensor Filter: passo 3, imagem 2 %32 Nikon D5000 Sensor Filter Replacement, Sensor Filter: passo 3, imagem 3 %32
    • Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
    • Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
    • Disconnect a seventh ribbon cable in the lower-right corner.
  4. Nikon D5000 Sensor Filter Replacement: passo 4, imagem 1 %32
    • Desolder the five wires attached to the back of the board.
  5. Nikon D5000 Sensor Filter Replacement: passo 5, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 5, imagem 2 %32
    • Remove the five silver Phillips #00 4x4mm screws.
    • One is hiding under the wide ribbon cable in the lower-right corner.
  6. Nikon D5000 Sensor Filter Replacement: passo 6, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 6, imagem 2 %32
    • Flip up the motherboard.
    • Remove the white cable connector by pulling it out of its socket with a spudger or fingernails.
  7. Nikon D5000 Sensor Filter Replacement: passo 7, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 7, imagem 2 %32
    • Remove the L-shaped ribbon cable from both of its connectors.
  8. Nikon D5000 Sensor Filter Replacement: passo 8, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 8, imagem 2 %32
    • Remove the three silver 5x5mm screws.
    • Between the metal backing plate and the standoffs for each screw is a copper washer. Don't lose them!
    • Flip the sensor board out.
    • Be extremely careful from this point on. Dust or scratches on any part of the sensor or its filters can affect picture quality.
  9. Nikon D5000 Sensor Filter Replacement: passo 9, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 9, imagem 2 %32
    • Remove the four silver 3.5x3.5mm screws securing the dust cover.
    • Pull the cover straight up to remove it.
  10. Nikon D5000 Sensor Filter Replacement: passo 10, imagem 1 %32 Nikon D5000 Sensor Filter Replacement: passo 10, imagem 2 %32
    • To remove the sensor filter, pull back the rubber gasket to expose the edge. Use a spudger or opening tool to carefully pry out the filter.
Conclusão
3 outras pessoas executaram este guia.
Jacob Rardin
Membro desde: 04/14/14
1.390 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-28, Maness Spring 2014 Membro de Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
Membros da 4
Autoria de 7 guias
Um comentário
Excelente guía, solo que debo cambiar las cortinillas y creo que es por el frente de la cámara
alcova35 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 5,221
