Ir para o conteúdo principal
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: passo 1, imagem 1 %32 Nikon D5000 Battery Door Replacement, Battery Door: passo 1, imagem 2 %32
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: passo 2, imagem 1 %32 Nikon D5000 Battery Door Replacement: passo 2, imagem 2 %32
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
Conclusão
Jacob Rardin
Membro desde: 04/14/14
1.390 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-28, Maness Spring 2014 Membro de Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
Membros da 4
Autoria de 7 guias
Um comentário
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 82
Duração total: 4,907
