Ir para o conteúdo principal
Nikon D40 Viewfinder Replacement
O que você precisa
  1. Nikon D40 Viewfinder Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Viewfinder Replacement: passo 2, imagem 1 %32 Nikon D40 Viewfinder Replacement: passo 2, imagem 2 %32
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Viewfinder Replacement: passo 3, imagem 1 %32
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Viewfinder Replacement: passo 4, imagem 1 %32
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Viewfinder Replacement, Viewfinder: passo 5, imagem 1 %32
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
  6. Nikon D40 Viewfinder Replacement: passo 6, imagem 1 %32
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
  7. Nikon D40 Viewfinder Replacement: passo 7, imagem 1 %32
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
  8. Nikon D40 Viewfinder Replacement: passo 8, imagem 1 %32
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
  9. Nikon D40 Viewfinder Replacement: passo 9, imagem 1 %32
    • The viewfinder has been removed!
Conclusão
Amy Chen
Membro desde: 01/23/14
193 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-19, Maness Winter 2014 Membro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 3,302
