Ir para o conteúdo principal
Nikon D40 Mainboard Replacement
O que você precisa
  1. Nikon D40 Mainboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Mainboard Replacement: passo 2, imagem 1 %32 Nikon D40 Mainboard Replacement: passo 2, imagem 2 %32
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Mainboard Replacement: passo 3, imagem 1 %32
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Mainboard Replacement: passo 4, imagem 1 %32
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Mainboard Replacement, Mainboard: passo 5, imagem 1 %32 Nikon D40 Mainboard Replacement, Mainboard: passo 5, imagem 2 %32
    • Remove the solder connecting the red wire to the mainboard.
  6. Nikon D40 Mainboard Replacement: passo 6, imagem 1 %32
    • Desolder the 4 smaller wires near the bottom of the mainboard.
  7. Nikon D40 Mainboard Replacement: passo 7, imagem 1 %32 Nikon D40 Mainboard Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to release the ribbon cables attached to the mainboard.
  8. Nikon D40 Mainboard Replacement: passo 8, imagem 1 %32
    • Remove the five 3.0mm Philips #1 screws holding the mainboard down.
  9. Nikon D40 Mainboard Replacement: passo 9, imagem 1 %32 Nikon D40 Mainboard Replacement: passo 9, imagem 2 %32
    • Lift the mainboard up to reveal the final connection.
    • Carefully detach the white cable from the board.
Conclusão
5 outras pessoas executaram este guia.
Joe Leija
Membro desde: 01/21/14
518 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-19, Maness Winter 2014 Membro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
Membros da 4
Autoria de 7 guias
Um comentário
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
Joseph Ruskiewicz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 4,296
