Introdução
My child dropped my Nikon D3100, after that my camera could not take pictures and the screen was giving an error. I found that the mirror was stuck. I here give the solution of how I solved the problem.
O que você precisa
The camera was dropped and cannot take pictures. There is an error on the display when I am trying to take a picture.
The camera house seen here is as it should be. I don't have any pictures of the problem, but i have illustrated it with the arrows. The small rubber dot was stuck on the side of the camera mirror.
I used a wooden rod (a soft material) to lift the mirror with very low force while trying to take pictures (The camera will try to open the mirror)
While slowly increasing the force to help open the mirror while still trying to take pictures the mirror released.
After reattaching the lens, see step 1. The camera worked 100% fine again :)
If the force you have to use become to large, contact Nikon to get a professional fix.
6 outras pessoas executaram este guia.
2 comentários
thank you very much. you help me
