Ir para o conteúdo principal
Nikon D3000 Motherboard Replacement
O que você precisa
  1. Nikon D3000 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Nikon D3000 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
    • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
  2. Nikon D3000 Motherboard Replacement: passo 2, imagem 1 %32 Nikon D3000 Motherboard Replacement: passo 2, imagem 2 %32 Nikon D3000 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
    • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
  3. Nikon D3000 Motherboard Replacement: passo 3, imagem 1 %32 Nikon D3000 Motherboard Replacement: passo 3, imagem 2 %32
    • Use the following process for removing all ribbon connectors.
    • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
    • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
  4. Nikon D3000 Motherboard Replacement: passo 4, imagem 1 %32 Nikon D3000 Motherboard Replacement: passo 4, imagem 2 %32
    • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
    • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
    • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
    • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
    • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
  5. Nikon D3000 Motherboard Replacement: passo 5, imagem 1 %32 Nikon D3000 Motherboard Replacement: passo 5, imagem 2 %32
    • Lift the tabs and pull away the ribbon connectors shown .
    • Lift the motherboard and disconnect the grey connector from the bottom.
    • Disconnect and remove the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Randall Heath
Membro desde: 08/25/15
851 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 14-7, Meier Fall 2015 Membro de USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 26
Duração total: 3,910
