Ir para o conteúdo principal
Nikon Coolpix S9700 Flash Housing Replacement
O que você precisa
  1. Nikon Coolpix S9700 Flash Housing Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement, Battery: passo 1, imagem 2 %32
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Flash Housing Replacement: passo 2, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 2, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 2, imagem 3 %32
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Flash Housing Replacement: passo 3, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 3, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 3, imagem 3 %32
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Flash Housing Replacement: passo 4, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 4, imagem 2 %32
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: passo 5, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: passo 5, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement, Flash Housing: passo 5, imagem 3 %32
    • Place your fingernail or a plastic opening tool in the space between the camera housing and the flash housing.
    • Carefully pry up on the flash housing. It will pop up automatically.
  6. Nikon Coolpix S9700 Flash Housing Replacement: passo 6, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 6, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 6, imagem 3 %32
    • Remove the two 4-mm J000 screws positioned at the bottom of the flash housing.
    • The housing will now be hanging only by the ribbon supplying power.
  7. Nikon Coolpix S9700 Flash Housing Replacement: passo 7, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 7, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 7, imagem 3 %32
    • Using your fingers or plastic opening tool, remove the back half from the front half of the flash housing. The front half will stay on.
    • Sudden or large force can rip the flash power supply off.
  8. Nikon Coolpix S9700 Flash Housing Replacement: passo 8, imagem 1 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 8, imagem 2 %32 Nikon Coolpix S9700 Flash Housing Replacement: passo 8, imagem 3 %32
    • Place a plastic opening tool on the clear lens of the flash.
    • Gently push on the lens to remove the front half of the flash housing.
Conclusão
Matt Staubus
Membro desde: 10/05/16
849 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-5, Lacy Fall 2016 Membro de USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
Membros da 4
Autoria de 10 guias
4 comentários
I dropped my coopix and cannot get it back in. Is there a way to replace the flash?
Charles Cezeaux - Responder
Dropped my Nikon Coolpix S9700 and broke the flash. It will not go back inside camera. Can it be replaced or repaired?
Does anyone know if it can be replaced or repaired?
I have done this to my camera. Cannot find replacement for flash. Can i use the camera as is?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,009
