Ir para o conteúdo principal
Nikon Coolpix S9700 Back Panel Replacement
O que você precisa
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: passo 2, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 2, imagem 2 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 2, imagem 3 %32
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: passo 3, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 3, imagem 2 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 3, imagem 3 %32
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: passo 4, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 4, imagem 2 %32
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: passo 5, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: passo 5, imagem 2 %32
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: passo 6, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 6, imagem 2 %32
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: passo 7, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 7, imagem 2 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 7, imagem 3 %32
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: passo 8, imagem 1 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 8, imagem 2 %32 Nikon Coolpix S9700 Back Panel Replacement: passo 8, imagem 3 %32
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
Conclusão
Matt Staubus
Membro desde: 10/05/16
849 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-5, Lacy Fall 2016 Membro de USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,119
